Ir para o conteúdo principal
The MSI GL65 9SD is a budget gaming laptop made by MSI computers released in 2019. Repair guides and further information can be found here.
9 Perguntas Visualizar todos
не работает микрофон(не программная ошибка)
Помогите решить вопрос с встроенным микрофоном, дело не программной ошибке, пытался несколько раз устанавливать Windows не помогло, думаю что это в аппаратной ошибке, но не знаю где подключается сам микрофон к плате, Webcam работает, и светодиод горит, но не микрофон
Google Translate:
microphone does not work (not a software error)
Help solve the issue with the built-in microphone, it's not a software error, I tried to install Windows several times, it didn't help, I think it's a hardware error, but I don't know where the microphone itself is connected to the board, Webcam works, and the LED is on, but not the microphone
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
Here’s a video that shows how to replace the screen in a MSI GL 65 laptop.
I realize that the screen is not the problem but the video is useful because at 5:00 minutes into the video it shows the cable that connects the camera, LED and microphone to the LVDS cable that connects to the motherboard.
If the microphone is not working it could be that the microphone itself is faulty or there is a wiring problem from the microphone back to the motherboard via the LVDS cable connection.
If the microphone and the wiring test OK then it may be on the motherboard which will make it harder to find unless you can find a schematic for the board.
I know that you said that it is not a software problem but have you seen this video about the microphone privacy setting in Windows?
Google translate
Здравствуй, Вот video, в котором показано, как заменить экран в ноутбуке MSI GL 65. Я понимаю, что проблема не в экране, а в том, что видео полезно, потому что через 5 минут видео он показывает кабель, соединяющий камеру / светодиод и микрофон с кабелем LVDS, который подключается к материнской плате. Если микрофон не работает, возможно, неисправен сам микрофон или проблема с проводкой от микрофона к материнской плате через кабельное соединение LVDS. Если микрофон и проверка проводки в порядке, возможно, он находится на материнской плате, что затруднит его поиск, если вы не найдете схему платы. Я знаю, что вы сказали, что это не проблема программного обеспечения, но видели ли вы это видеоо настройке конфиденциальности микрофона в Windows?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Denis One será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 446
