Ir para o conteúdo principal
Modelos: - multipractic - multipractic plus - K3000 - K3050
The central spindle is split.
I managed to split the central axel due to a very hard piece of cheese. The split has spread out so the tools won’t go on. I have another machine to replace it, but I was cheated as this doesn’t work either. But it can be used for spares. Is there anything you can advice me on, or help me get this repaired somehow? I am in Manchester M9.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Hi there, did you manage to get this fixed? I ask as I have the same machine.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
This guide helps to fix the issue.
Esta resposta foi útil?
Pontuação 1
Auch bei mir ist die Mittelachse gerissen. Gibt es eine Mail-Adresse oder einen Account auf Telegram, Signal oder auch WhatsApp, damit ich Fotos dazu zeigen kann? Danke vom Zorn
Pontuação 0
Adicionar a sua resposta
Janis Dolan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 534
