How do I reattatch a joycon rail
so i broke off my right joycon rail and have no modding experiance
Esta é uma boa pergunta?
Depends how it’s broken. Did you drop it? Or pull it? If the rail is still intact, you have to carefully open the Joycon, put it back and close it. For that you’ll need absolutely a TriWing (Y head) screwdriver.
If the rail is broken, you’ll need a new one.
Same thing if it’s the rail on the Switch’s side.
Esta resposta foi útil?
How do I put it back in?
@Tgw Gaming We can't give you an answer without knowing just what's broken. Is it the rail on the joycon, or the rail on the Switch?
The rail on the joy con
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 311
Depending on how you broke it you might be able to but it back on. Is it possible you can attach a photo of the joycon?
por Bri
same problem here. are the two flat cables from the rail intact like mine are?
por Hamm Khan
