Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
After upgrades still runs like crap
Upgraded the hard drives upgraded the RAM replaced the logic board after I spark it putting in a new battery like a jerk, still runs slower than molasses ran clean my Mac X & still is giving me issues. Only runs great in safe mode but I Don’t have access to certain functions.
and it’s worth noting that it took three years for the logic board to become available in that time I only ran the computer on safe mode so when I replace the logic board I wiped the hard drive to start with a clean version of High Sierra but it was a nightmare trying to load it from the Mac mothership. Anybody have any suggestions? Oh yeah and the cursor just stopped working I have to use an external mouse
Esta é uma boa pergunta?
Pontuação 1
11 comentários
Well I would first run the onboard diagnostics to see if any errors popped. Restart the system and press the D key. Let us know what you get for errors.
Reference: Mac startup key combinations
Review this Your Hard Drive Cable Is A Ticking Time Bomb a common issue is a worn or damaged HD cable.
por
Ok will do - any Ideas as to my the cursor suddenly stopped working? I replace the trackpad and it’s still not working should I replace the trackpad cable?
por
@dacnjnc - Once you get the diagnostics output it should give us some ideas which way to go.
por
Ok, running diagnostic now
por
Also a HDD won't be as snappier as an SSD but that's another topic.
Dan is on the right path for you to run the AHT (Apple Hardware Test) now called Apple Diagnostics to check for error codes BEFORE the OS is started. Seems like there's still an issue after you replaced the board.
por
Exibir mais 6 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Bingo! We now know you have a thermal sensor issue within the Trackpad has a problem. That explains your systems sluggishness! SMC is in Safe Mode lowering the CPU’s clocking and ramping up the fan speed.
From the Apple service guide:
The error is a thermal sensor error for missing or abnormal reading for Trackpad/Palmrest (Ts0P) sensor
The trackpad device may have an open connection or damaged device. Reseat flex cable while inspecting for cable or connector damage (on both logic board and trackpad flex cable.
Here’s the needed part MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad and here’s the guide to put it in MacBook Pro 13" Unibody Late 2011 Trackpad Replacement
Imagem de MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Produto
$59.99
Esta resposta foi útil?
Pontuação 3
6 comentários:
I already replace the track pad but not the flex cable - my friend has the same MacBook but it died (my next project) so could it just be the flex cable?
por
@dacnjnc - The sensor is on the cable! But I would replace both together as the cable can get damaged putting it in (over flexing it breaking the solder joints)
por
You guys are the best, I let you know how it goes
por
Gentleman! The Eagle has landed! We have liftoff! My Silver Mistress is back on line! Faster than ever! Dan, you were spot on! Shes never worked better! Thanks so much! Javen, so much for needing a new computer. Ifixit!
por
Great to hear! Don't forget to accept the answer - Thanks!
por
Exibir mais 1 comentário
Adicionar a sua resposta
David Curran será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 198
