Introdução
Use this guide to replace a broken trackpad.
O que você precisa
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the following two screws:
One 5.6 mm Tri-point screw
One 13 mm Tri-point screw
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the flat end of a spudger to carefully pry the trackpad connector up from its socket on the logic board.
If necessary, carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
Carefully push the trackpad connector and cable down through the slot cut into the upper case.
It may be necessary to use a spudger to help get the trackpad connector past the edge of the logic board.
Once the cable has been completely pulled through its slot in the upper case, pull the trackpad away from the outer edge of the upper case and remove it from the machine.
To remove the flex cable from the old trackpad, first flip open the latch on the ZIF connector, opposite the cable. Then, apply a little heat from a hair dryer or iOpener to soften the adhesive securing the cable to the trackpad, and carefully peel off and remove the cable.
75 outras pessoas executaram este guia.
8 comentários
any tips on adjustment of the height screw?
don't turn the screw too much, or you'll destroy your trackpad
I had a lot of trouble getting the new trackpad to work. The left side of the track pad (about 2cm) was responsive. The rest of the track pad was dead. I played with the torx screw to adjust the click pressure and it had no effect. I cleaned all the gunk out from around the perimeter of the trackpad when it was removed. I tested without the battery in place to ensure that battery pressure was not the problem.
The actual hardware remove, reinstall took about 15 minutes at most and was very straight forward.
The trouble shooting has been the tough part.
What was the fix?
Jocray -
I replaced the track pad successfully, but it did not fix the problem I was having. When I want to drag and drop a file, I really have to push down on the track pad hard to hold on. Its a little bit better with the new pad, but I still have a hard time with the lower left corner of the track pad grabbing stuff. Anyone have any ideas of what the issue could be?
