cause vertical bars on display
What causes blinking vertical bars on display
Esta é uma boa pergunta?
Does an external display show a clean image? If it does then your display assembly will need to be replaced. If the image is also messed up then your logic board graphics services is messed up.
My money is on the display 15” MacBook Pro Display Assembly, Apple T/N 661-8310 and here’s the guide MacBook Pro 15" Retina Display Mid 2014 Display Assembly Replacement
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 36
You likely banged the system damaging the display assembly.
por DanJ
