Ir para o conteúdo principal
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
Idle Problems/ Car shakes
My 2002 Mazda 626 car shakes alot. I was told it was the idle and Im trying to find out, Where s it located? Can I do it myself and what does it require? If a pic can be sent or posted it would be greatly appreciated
Esta é uma boa pergunta?
Pontuação 1
1 comentário
What size engine is it and what type of transmission is it? Do you have the service engine light on? Have you tried to take it and get it checked on an engine analyzer?
por
Adicionar um comentário
6 respostas
Solução escolhida
Take it in to an Auto Zone and get a free computer diagnostic, then fix what it tells you is wrong.
Esta resposta foi útil?
Pontuação 4
1 comentário:
Auto Zone will only do the diagnostics if your Check Engine Light is on.
por
This may be a little late, but my 626 used to have a very rough idle, and would sometimes shut off from it. It ended up being a manifold gasket was broken which caused a vacuum leak. I had a '98 626 LX with the 2.0L IL4 engine and the 5-speed manual transmission.
Pontuação 2
Hi,
if the car shakes alot it´s most common not a problem of the idle, it´s a hint that you should take a closer look at your engine because there is something wrong with the air-fuel mix, or the ignition.
The idle was set before to a proper rpm. As long as the carburator or the throttle body wasn´t changed, the idle shouldn´t change.
I would take a closer look to the ignition system, a.e. spark-plugs, cables, rotator a.s.o., the fuel system, a.e. carburator or injection, filters, fuel lines, fuel pumps, injection black-box and at last at the air intake, sometimes its just a messed air filter.
Pontuação 0
Put some platinum plugs in
Pontuação 0
I have a 98 Mazda 626 lx 2.0 L 4 manual 5 speed tranny started hiccuping about two weeks ago. At first it was mild than it got worse and almost constant . I pulled the thermostat and it appeared to be stuck shut. Car than ran fairly good for a few days with very minor hiccups but didn't last long. Car started hiccuping really bad yesterday , tach gauge goes crazy when it has these hiccups, than car stalled while driving and wouldn't restart this time. Does anyone has any answers of where to start first? Didn't have these issues until I replaced the clutch a lil over a month ago.
Pontuação 0
I had a similar experience and several attempts of DIY I got it solve. I had changed:
Fuel pumps (from low pressure to higher)
Spark plugs & wire
Sprayed carburetor cleaner through the intake to clean throthle body
Etc etc
I finally decided to change the FUEL PRESSURE REGULATOR and my problems went away.
Now it starts at first crank effortlessly. And drove well.
Pontuação 0
Adicionar a sua resposta
jresto973 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 17,313
