Not Turning On after install of Big Sur
Hello, I have recently updated my MacBook to big sur and have not been able to turn it on since.
I have reason to believe it is a problem with the USB port not charging it or maybe the logic board.
Esta é uma boa pergunta?
Pontuação
Does the backlight turn on or do you hear a startup chime when you press the power button? If you press the power button while holding the option key does it show Macintosh HD?
por Devnol
The backlight doesn’t turn neither do I here a start up chime, I believe it might be a faulty port or logic board
por Christian Commaille
