Ir para o conteúdo principal
A Pistola de Pregos sem Fio Ryobi P320 (2016) é uma ferramenta versátil projetada para tarefas de marcenaria e construção, oferecendo operação sem fio e compatibilidade com o sistema One+ da Ryobi para maior usabilidade. Com recursos como profundidade ajustável e tecnologia Airstrike, ela proporciona um desempenho conveniente e confiável para diversas aplicações, enquanto as técnicas de manutenção e resolução de problemas garantem uma funcionalidade duradoura.
How is this part not available?
My nailer took a tumble down the stairs and broke the metal bracket that the “no mar contact tip” attaches to (part of the depth set mechanism and the piece that sticks the furthest away from the body of the tool.) I've searched all the parts websites and it seems every o-ring and screw and other part is available, but I cant find this one and can't even find a good name for it. Not willing to buy a new tool over a $5 part. Can anyone help?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I also have the same problem, the tip broke off. Can I buy the assembly which includes this part?
Steve
claretsfan@gmail.com
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Do you see the part on this diagram?
Imagem
If so, this site should help identify it and may offer it for sale
It appears that that is part of the magazine assembly.
Imagem
Imagem
https://www.ereplacementparts.com/ryobi-...
Esta resposta foi útil?
Pontuação 2
6 comentários:
Thanks Issac, but no, it's not a numbered part on that diagram /website. It’s the metal piece that screw 36 goes into after piece 35.
por
@anonnimity Updated answer. Looks like it's part of an assembly, not sold as separate.
por
Ryobi OEM 79007001084 Nailer Driver Assembly R213BNA R150FSA R213BNE
por
It's called a "Work Contact Element" but part #79007001084 for the P320 does not fit on the assembly. Part 1084 has the same holes and fits on but it's a solid piece of metal. The one that broke on mine (Same as above) has metal grooves down the body and the width of the contact element isn't wide enough to slide over the nail tray. I've not found a replacement part the same as what broke.
por
The piece you are looking for is not marked and I'm having the same issue! it goes through 35 and is the piece that you attach the no mar pad to! Drop your tool and it breaks off. At this point I'm so disappointed that I am now in the process of replacing my Ryobi tools! Never by Ryobi they are junk!
por
Exibir mais 1 comentário
Pontuação 2
It sounds like the specific part you're referring to is the metal bracket that houses the "no mar contact tip" and is integral to the depth set mechanism of your Ryobi Cordless Brad Nailer P320 (2016). Unfortunately, without a specific part number or a clear description, finding this part can be challenging.
One suggestion is to reach out directly to Ryobi customer support. They may be able to provide assistance in identifying the part and possibly ordering a replacement for you.
Pontuação 1
Mine was Part 42 here: https://ryobipower.ordertree.com/model?m...
Pontuação 0
1 comentário:
sorry, was for trhe P321...
por
Adicionar a sua resposta
anonnimity será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 50
Ao todo: 2,497
