Ir para o conteúdo principal
O smartwatch de quarta geração da Apple, com conectividade celular opcional, lançado em 21 de setembro de 2018.
Screen white after replacement
Hi everybody
I had to change the screen of my Apple Watch 4 44mm. For that, I bought a locked watch with a perfectly working screen. After switching the broken screen of my watch with the working one, the replaced screen is only white. I checked the cables and changed the Touch Force sensor as well. The screen is still white. Does anyone have any idea why?
Thanks and greetings
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Maybe screen curtain is active, have you tried to disable it?
"Use Screen Curtain on your Apple Watch
Use your iPhone to turn on Screen Curtain for your Apple Watch:
  1. On your iPhone, open the Apple Watch app and go to My Watch.
  2. Tap Accessibility > VoiceOver > Screen Curtain. This setting keeps Screen Curtain active whenever VoiceOver is on.
  3. To turn Screen Curtain off, repeat these steps."
Esta resposta foi útil?
Pontuação 0
Did you find a solution? having the same issue.
Pontuação 0
Adicionar a sua resposta
DeFidel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Ao todo: 868
