Ir para o conteúdo principal
O Controle Sem Fio Xbox One Modelo 1698 foi lançado pela Microsoft em 2015, junto com o controle Modelo 1697. Este controle é semelhante ao Modelo 1697, com modificações internas. Ele possui mais recursos do que um controle básico, como botões analógicos (thumbsticks) removíveis e um D-Pad de metal. O controle foi projetado principalmente para uso em console, mas é compatível com PC.
Why does the right trigger activate without touching it
My brothers controller recently started to get the right trigger problem where it would constantly activate but the left trigger wouldn’t work is there anything that my brother and I can fix this problem.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
My RT and LT buttons press themselves and RB is acting like the start button. Also my right stick isn't doing anything. The ABXY buttons work perfectly fine though.
por
Adicionar um comentário
1 resposta
I've had controllers do this before. A sign that it's taking to much physical wear. Usually, a controller will do that when its hardware is resting on the internal components. Or the “middle man” component isnt doing its job because it is broken/worn or out of place. The only way to know would be to take it apart. Look for an internal part that gives the trigger resistance so it isnt ever resting on the internal button after you have applied pressure. Then see if it's the trigger itself by taking off the front controller plate and seeing if the button makes contact with the necessary button. If so, check the internal buttons to see if they are stuck or in a bind. Press them a few times and see if the console receives signal. Make sure everything is secure and safely reassembled.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andrew Urquizo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 47
Ao todo: 3,603
