Anyone know how to open this up for cleaning?
I have a Coolscan IV slide/negative scanner and would like to clean it. There is gobs of dust on the element. Can't really just get in there with an air can.
There are screws holding the steel shrouding on the back, but I cannot seem to get the plastic front plate off. Not sure if it should pop off, or if there are other connectors.
I would appreciate help here.
Many thanks!
Esta é uma boa pergunta?
1 comentário
If you check on the link I sent you, it says "To get the front faceplate off, use a flat screwdriver to gently pry the tab away from the chassis"
por oldturkey03
