Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Click wheel not playing/pausing
The click wheel on iPod Classic (Late 2009) doesn't work for playing or pausing. To get it to play I have to press it 20-30 times just below the play/pause symbols. Once it's playing I just remove the headphone jack to pause playback. All other functions work properly forward/back, Menu, volume control, and the center button. Unit charges normally, and is recognized by iTunes/Windows. Is it just the click wheel that needs replacing?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
place your iPod in diagnostic mode "Menu + Center >Previous + Center" In the diagnostic mode it allows you to test your click wheel. You can check on it. At this point I would think that if everything else works the way it is supposed to, just change the click wheel. Not a terrible job, bit of a bear to open the iPod, and cost effective. Once you change it re-evalaute and see what you got. Make sure that when you do change it, take a look at the micro switches on the logic board. They have to correspond with the click wheel.
iPod Classic Click Wheel Replacement
Esta resposta foi útil?
Pontuação 3
4 comentários:
Thanks for your reply. Looking at slide 34 in the instructions I see the micro switches you are talking about. Now I'm wondering if the micro switch that corresponds with the play/pause button is bad. Can I test that somehow?
por
You can check the switch through the diagnostics as well, It does give you the option. You could also disassemble the iPod and test the switch with a multimeter.
por
The keypad button test fails on the Pause/Play Key. Once I figure out how to get out of this testing I will try the Wheel test.
por
okay sounds good. let us know
por
Adicionar a sua resposta
mike marcott será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 11,481
