Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Perguntas Visualizar todos
Replaced Power Supply and Fan spins at full speed, iMac does not boot.
I suspect that the SSD temp sensor is bad. I installed this sensor years ago when I replaced the HDD, then later upgraded the HDD to SSD… so maybe the sensor is bad… I’m not sure.
I did order a new sensor:
OWC In-line Digital Thermal Sensor for 27-inch iMacs (macsales.com)
https://eshop.macsales.com/item/OWC/DIDI...
I’m hoping it will fix the issue with the fan running at full speed when I power on the iMac.
If that does not fix it… I might have to replace the logic board. Not sure what the issue could be.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You may be able to put iStat on there and figure out which sensor is acting up. From there you can formulate a plan to fix.
https://bjango.com/mac/istatmenus/
Esta resposta foi útil?
Pontuação 0
Yeah but iMac won’t even boot up, plus I need to reinstall MacOS on the new SSD
Pontuação 0
3 comentários:
sorry, I missed that. Are you seeing anything on screen when it tries to boot?
por
@memphismac No, not seeing anything... I'm pretty sure it's the logic board... because I connected the original HDD and still nothing.
por
Just to be clear the iMac is not getting any power or anything right?
I guess next step would be to open it up, plug it into power and look at the diagnostic LEDs and see what they are showing. LED 1 means it's getting trickle voltage to the logic board. If LED 1 doesn't light up then it's most likely the Power Supply. LED 2 will turn on when you push the power button and the computer begins to startup.
por
Adicionar a sua resposta
kamilgoslawski será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 59
