Ir para o conteúdo principal
14 MP digital camera, released in 2010.
4 Perguntas Visualizar todos
Why wont it charge the battery?
it wont charge the battery, and it is not the battery thats the problem. when i connect it to power it wont turn on and it justs blinks repeatedly for a short while and then stops? Whats wrong with it? i bought it refurbrished.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
6 respostas
Pergunta mais útil
Status LED Description
Green (blinks slowly) Charging normally
Off Charging finished
Green (blinks quickly) Error
I would suggest to use a AC charger and not the USB from a computer. If your battery is discharged to low the USB port will not supply enough amperage to charge the battery. I would definitely start with a new battery, and an external charger. That way you know for sure what works, especially since this is a "refurbished" camera. You could look at places like this for your parts. Good Luck
Esta resposta foi útil?
Pontuação 2
I don't know what to do it does the same thing to me and it won't charge at all please help Me
Pontuação 2
Mine was my sisters but, she said the t it did't do anythng a long time ago now 4/3/2016. I have found it in a box at my house and found the charger but, it didn't charge. So I went to youtube and search up how to charge it but everybody didn't show how to charge it and now I'm telling you. So, can you help me please anyone I need it to work.
Pontuação 2
I also have that problem with the battery. I have another complaint. The button to turn on the camera is so small that I have a terrible time getting it on. I am 74 years old and when it goes on, I love the camera but it is so frustrating for instance, when I was at my grand daughters college graduation and she was coming down the path going to the stage and I could not get the camera to turn on. I was so upset as this only happens once in my grand daughters life. I originally had a cannon and it was great until someone stole it from me. If I cannot get this problem along with the battery problem fixed, it looks like I am going to ask my children to get me another cannon for my birthday.
Pontuação 1
i have a sanyo its not that old and and the back screen dont come on i check evevrything and i dont know what to do the store wont take it back
Pontuação 0
1 comentário:
First, what Sanyo is it? Second, you are saying it is not coming on, any led flashing? Does anything happen to the camera when you try to turn it on? Have you charged your battery? Do you have a multimeter to check your battery? What have you tried so far?
por
Trying to charge Sanyo VPC-T1496. Manual says green light should be blinking slowly; it is steady. What might be the problem?
Pontuação 0
Adicionar a sua resposta
Christian Quan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 28
Duração total: 4,115
