Ir para o conteúdo principal
O Google Pixelbook Go é um Chromebook premium do Google, apresentando um chassi de magnésio durável com design minimalista. Lançado em 2019. Número do modelo: GA00521-US.
Re-insert clamshell pin into hinge
Imagem
One end of the hinge on the Google Pixelbook Go has slipped out of place. I do not know how to reinsert it. The two pieces of the clamshell do not feel flexible enough to bend and allow the pin to slip back into the hinge.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
4 respostas
Curious what you ended up doing here. Your issue (and mine) is that the hinge itself is broken. This is caused my the screws loosening causing a torsional flex in the hinge when then snaps it.
The screws loosen over time due to hinges being too tight.
Google isn’t supporting the devices and there’s no way to get replacement parts.
Esta resposta foi útil?
Pontuação 0
2 comentários:
TL;DR Don't buy Pixelbooks.
I returned the broken Pixelbook to the seller and got back 80% of the purchase price. The money I got back was enough to buy two Lenovo Chromebooks w/ 8GB and touch screens.
por Compartilhar
I have the same Pixelbook AND the exact same issue. I have another problem as well, when the right hinge is lowered, the display goes black, everything still works, the device isn't turned off, I believe it might be a severed display cable
por Compartilhar
It seems that the hinge is snapped from the image. Could have happened when the LCD is accidentally pushed exceeding the limit. Can be fixed by removing the back cover and swap out the damaged hinge.
Pontuação 0
I was able to buy a hinge on eBay (at outrageous price for such a small element) and replace it, otherwise you can replace the whole unit for $$$.
Pontuação 0
@piotrkaminsk163 How did you replace it?
Pontuação 0
Adicionar a sua resposta
Aaron Hoffer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 26
Ao todo: 1,639
