Ir para o conteúdo principal
Dispositivo ativado por voz sem usar as mãos da Amazon, alimentado pelo Serviço de Voz Alexa. Modelo S04WQR.
Echo dot power supply
My 3rd gen echo dot is supplied with plug of two flat pins, but I live in the uk with 3 pin sockets. Can anyone please tell me what I need for a plug? I’ve tried a plug adapter but it won’t work with this, so I don’t know what I need to buy.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi
It would be very helpful to post a picture of the power adapter.
But, if you say it has 2 flat pins, then most likely it is the US version. You can either buy a US-to-UK wall adapter, a generic all-in-one travel adapter or you can buy the UK-version of the Echo Dot power adapter (this being I suppose the most expensive option).
Cheers!
Bogdan
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hi Brogdan, thank you for your advice. I did try a travel adapter, but it must have been faulty as did not work. I have since tried another adapter and success! Appreciate your response, Happy New Year!
por
Adicionar a sua resposta
seritacampbell@hotmail.com será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 629
