Which iPod Touch battery is better?
Which model battery is better, the 616-0404 that ifixit sells here or the 616-0401? Which lasts longer? Do certain batteries work with certain itouches?
Esta é uma boa pergunta?
Apple's 616-0401 battery
Compatible with and fits these models: Touch 2nd 4GB Touch 2nd 8GB Touch 2nd 16GB Touch 2nd 32GB Touch 3rd Touch 3rd 8GB Touch 3rd 32GB Touch 3rd 64GB
Compatible Part Numbers: 616-0401, 616-0404, DAP284846PA, MB531LL/A, MB533LL/A, MC008LL/A
3.7 volts
800 mAh
Original battery model: 616-0404
Replacement Battery for iPod Touch 2nd and 3rd Gen
Li-Polymer battery 3.7V 900 mAh Li-Polymer
Designed for iPod Touch 2nd Gen
In theory the 0404 would provide you with a bit longer time. It appears to be the choice if that is what you are looking for. Of course, always remember that most of those numbers are strictly academics, and will depend on your usage of the device. Also, just because the numbers match, that does not tell you that you have a great battery. You have something that will fit your device and should work. I would go with a reputable seller that has good customer support when needed.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 892
