Ir para o conteúdo principal
A Fujifilm X100T é a terceira geração de câmeras da série X100, lançada no final de 2014 pela Fujifilm Corporation. Ela está disponível em duas cores: preta e prata, e pode ser identificada por um "T" maiúsculo na parte frontal. Possui Wi-Fi e pode tirar fotos de 16 megapixels.
X100 F bottom plate replacement
Hi!
I have to replace the bottom plate od my x100F. I have watched X100T dissesembly guide on this site. It is not clear do I have to peel the leatherette or do I just remove the six screws at the bottom of the camera with the leatherette on. Did anyone took appart the x100F?
Thank you
Neven
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
I took both cameras apart and removing the bottom plate of the X100F is way easier than with the X100T. You just need to remove 5 screws in the bottom. One at the battery compartment and the four remaining ones on the opposite side – leave the two at the tripod mount where they are for now. You can then remove the bottom plate. If you need you can unscrew the tripod mount to move it to the new bottom plate.
Since your post has been here for a while this might not be of interest to you anymore, but maybe it is helpful for somebody else in the future ;)
Cheers
Chris
Esta resposta foi útil?
Pontuação 1
Hello Chris, thanks for you answer. I did found someone who made the replacement but still I am sure that one more screw must be removed, the one on the side of the camera (the one with the focus selection lever. Please verify it, so people do not wonder about it, if they have to do it.
Cheers
Neven
Pontuação 0
2 comentários:
My apologies, I suppose you are right, Neven. I will remove the bottom plate in the evening to verify. Maybe I take some pictures and post them here.
por
Hi Chris,
Have you had a chance to verify it?
Thanks,
M.
por
How do we buy a replacement base plate?
Pontuação 0
1 comentário:
I am selling mine. It has slight marks on it (that is why replaced mine.)
por
Adicionar a sua resposta
Neven Miškulin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 34
Ao todo: 1,232
