Ir para o conteúdo principal
Repair information for the Beats Studio 2.0 wired headphones. Originally released in 2013. Model number: BT OV STU BLK.
Why is audio going out in one side?
Sound on the left side goes in and out depending on how the headphones are adjusted and sitting on my head. I can usually get sound to come back by pressing the headphones close to my ear but I have to keep my head in a fix position.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Bryan Gallagher sounds like either the crossover cable has a short in it or some connection on the driver (speaker) has come loose. This teardown Beats Studio 2.0 Exploratory Teardown should help you getting to the connections. Check for anything abnormal looking. If unsure post some pictures of what you find with your QUESTION Adicionar imagens a uma pergunta já existente
That way we can see what you see. Remember the reason for iFixit to host this forum is to keep devices out of the landfill and to empower everyone to repair their own devices. So keep on repairing away; Repair is Noble
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Beats Studio 2 Wireless
Guia
Moderado
Esta resposta foi útil?
Pontuação 1
Beats are actually very very cheap headphones with a large markup. Therefore they are actually very poor quality, in build and sound. There’s most likely an internal wiring problem, a loose connection or frayed wire.
You might be able to fix it if you open it up, but I would suggest just buying a new pair of headphones or taking it to get fixed by a trained technician
Pontuação 0
Adicionar a sua resposta
Bryan Gallagher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 57
Ao todo: 1,593
