Ir para o conteúdo principal
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Perguntas Visualizar todos
Does not power on
I got water spilled logic board, i have already clean it
but the strange thing the it does not power on and the charge light goes from amber to green for a second, but if i disconnect battery and plug it it again then i turn it on, well it turns it on again by it self
i can use the laptop but i cannot shut it down or i will have to take it apart again and disconnect the battery
does anyone have a clue what is going on
p.s i have reset the smc
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
See if after you've started the system you can plug in the battery. Did the system shut down on you? If it did then you likely need a new battery
por
Did have a spare battery to test but with no luck
por
Adicionar um comentário
1 resposta
This sounds like you still have damage from the spill. Did you fully remove the logic board? I would start there. Inspect the back side.
Esta resposta foi útil?
Pontuação 0
2 comentários:
yes i inspect the chip, but it can be some soldier balls underneath is damage? its glue to the board and i dont have skills to reball it
por
Was there damage even visible? Use the image I posted to compare yours to.
At this point you'll need to decide if you can get someone to fix your logic board or you'll need to replace it.
por
Adicionar a sua resposta
Palli será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 42
