Does not power on
I got water spilled logic board, i have already clean it
but the strange thing the it does not power on and the charge light goes from amber to green for a second, but if i disconnect battery and plug it it again then i turn it on, well it turns it on again by it self
i can use the laptop but i cannot shut it down or i will have to take it apart again and disconnect the battery
does anyone have a clue what is going on
p.s i have reset the smc
Esta é uma boa pergunta?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
See if after you've started the system you can plug in the battery. Did the system shut down on you? If it did then you likely need a new battery
por Dan
Did have a spare battery to test but with no luck
por Palli
