Lg g4 Wifi entegresini nasil degisebilirim
Lg g4 wifi problems. How can i change wifi chip
Esta é uma boa pergunta?
Hi,
You don’t say what the problem is or what you have tried to do to fix the problem but replacing the WiFi chip seems a bit excessive.
Have you tried disabling the smart network switch to see if this fixes the problem?
Here’s how to do this:
Enable the mobile data connection.
Then go to Menu -> Settings -> Wireless and uncheck the smart network switch option
Your internet connection may not be so stable anymore as it won’t be switching between the WiFi and the mobile network internet connection trying to achieve the most stable connection possible.
Also try wiping the cache partition in case there is corrupted cached data that is affecting the WiFi
Esta resposta foi útil?
I did what they said but it didn't improve
@Yusuf Sonmez
Please Unaccept my answer as it didn't work for you.
What is the problem with the WiFi , you didn't say?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 166
