How to change charging port
cant plug in charging cable Think i messed up port
Esta é uma boa pergunta?
Hi,
You’re lucky in that the charge port is easily replaced as it is located on a separate removable board i.e no soldering required.
Here’s the Alcatel One Touch Fierce repair guides that will help you to gain access.
Here’s a video that shows how to remove the board.
Here’s a supplier of the part. It is only an example to give an idea of the cost of the part. There are other suppliers online that may suit you better. Just search online for Alcatel One Touch Fierce 7024 charge port dock to get results.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 44
