Ir para o conteúdo principal
Installing MAC X OS
I have Formatted the Original HDD of the MAC A1150 using the DiskUtility of another MAC so that the Formatting Type is compatible….
I have created a Bootable USB with El Capitan Using command Line by the following command.
sudo /Applications/Install\ OS\ X\ El\ Capitan.app/Contents/Resources/createinstallmedia --volume /Volumes/TOSHIBA--applicationpath /Applications/Install\ OS\ X\ El\ Capitan.app
The CLi successfully formatted the USB and installed the Installation media for El Capitan enabling the USB to be a Bootable Device… However, When I insert the USB into the MAC > Power up the Mac whilst holding Option And then selecting onto the Bootable Device I am getting presented with……..
A FOLDER WITH A QUESTION MARK INSIDE !! Any ideas to why or how I can resolve?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
You’re trying to install OS X 10.11 “El Capitan”, but assuming you put the correct model in (15-Inch MacBook Pro from 2006), the latest version compatible with that model is Mac OS X 10.6 “Snow Leopard”. I could be mistaken, but I’m guessing the reason you’re seeing that symbol is because El Capitan isn’t compatible with that machine.
Esta resposta foi útil?
Pontuação 1
Mac A1150 can not install from external drive has to be internal drive/ dvd drive only!
Pontuação 0
Adicionar a sua resposta
Fire Base será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 1,187
