Ir para o conteúdo principal
Batedeira de bancada Artisan Series de 5 quartos com cabeçote basculante da KitchenAid, modelo KSM150PSER. Todos os modelos que começam com KSM150PS são o mesmo dispositivo, apenas com cores diferentes.
Wire whisk stuck on
The wire whisk is stuck on the rotator shaft. I’ve turned it up and to the left but it’s not coming off. Also not sure if the rotator should be moving but it does in its planetary way while trying to remove it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
If the planetary is moving something has probably failed inside the gearing mechanism. You should be able to grip the drive shaft with needle nose pliers and remove the whisk easily. Keep in mind that it has to slide upwards slightly to disengage from the “bayonet pin” on the drive shaft though. Make sure you unplug at outlet before attempting!
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you. I think i need to return it then as its only a week old and the rotary keeps moving as I try and remove it. thank you.
por
Actually, I had put some vegetable oil on it with a tip and still couldn't get it off but I managed to do it with the pliers so maybe i don't need to send it back....thank you.
por
Adicionar a sua resposta
wendy macdonald será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 547
