Ir para o conteúdo principal
Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
142 Perguntas Visualizar todos
VGA No Signal when Windows XP logo Appears
Hello guys ,I hope you are doing well! So I am trying to boot up an old pc (from 2006 to be exact) using a Samsung HDD with Windows XP installed. I have selected it to be the first one in boot priority. When it's booting its asking me which mode I want to enter (safe or normal).
Whatever I select , it tries to boot ( showing me the Windows XP logo) and immediately stops and a message saying VGA NO SIGNAL Appears.
Any ideas would be greatly appreciated :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi
What is the make and model number of the PC or the motherboard if it is a custom build?
Was the HDD with Win XP already installed, taken from another computer?
If so you will have troubles making it start when connected to a different motherboard as the hardware will be different and therefore the wrong drivers will be already installed in the OS.
This link may be of some help
Esta resposta foi útil?
Pontuação 2
2 comentários:
So this is the machine : https://www.manualslib.com/manual/10347/...
And Yes I am using an external HDD (with the OS) from another PC.
por
Hi @GO4GAME
I know nothing about servers but looking at this link the OS may have to be newly installed on a HDD in the server and not be an existing installation from another PC but i may be wrong about that.
Also it appears that even then there may be problems. Maybe try a Linux install as suggested in the link
Sorry I can't help more with this
por
Unplug the VGA, then Wait for a couple of minutes, and then reconnect the VGA cable to your computer and monitor . Plug the Power cable back to your computer and monitor. Turn on . Try using an external monitor.
Pontuação 0
Adicionar a sua resposta
GO4GAME será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 185
