not sure what its called but it has 6 points and it is not the smallest size of it, as I have a drill bit that is 6 points but smaller, and the 2nd smallest one worked for me. However, the more important things to know, at least for my model 81N8 or 818N, is that one of the screws towards the spacebar side is shorter and it has a washer inserted inside the lid. This makes the screw stay inside after infinite amounts of rotating it loose. I yanked it out essentially, but what helped was to fit my fingernail underneath the head of the screw as to act like a washer on the outside, and then a firm pull while you do so will get it out.
Also important to note is that all the screws have the blue Loctite on them. Taking out the screws were slightly challenging but doable. However, putting the screws back in ended up with my stripping half of them—generally more friction and some of the Loctite got loose and made the screw stop early or fasten early. Not knowing that that was happening, I over tightened the screw while a third of it was still outside.
I only screwed back on the middle screw and am hoping the clips do their job for the remainder of the life of this laptop. I was panicking when I couldn’t unscrew the screws after they stripped >50%.
I was replacing the fan and upgrading the ram. The screws for the fan also had the blue Loctite, so I am assuming all screws on the %#*@ laptop have the blue Loctite. I figure this is useful information to those who know what to do with it. have fun disassembling your laptops because I sure as !&&* didn’t.
1 comentário
Can you please add a picture of the screws?
Here is a guide that shows hot you add pictures: Adicionar imagens a uma pergunta já existente
por Erik Eriksson
