Ir para o conteúdo principal
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
interface port on iPod
My friend leaves his ipod classic plugged into his stereo in his truck at all times. It has been bumped a few times and the cable no longer makes a good connection all the time. Is there a way to reinforce the port on the logic port so it will not fail?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If the cable is loose at the bottom of the iPod, the dock connector, then there is really not a lot that you can do. The little spring pins may just have worn out. I would try a new cable and see if that makes better contact. The only way to fix the dock connector is by replacing the logic board. Not a terribly expensive or difficult undertaking.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Matt Shirey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 520
