Ir para o conteúdo principal
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Perguntas Visualizar todos
Diagnosis code PPF003 question
My fans is running constantly. The diagnostic code is PPF003. Apple advise that it is a fan issue and that it should be taken to a service center. But surely it’s the thing that switches the fan on and off that’s the issue. I have reset the SMC. I don’t want to replace the fan only to find that the new fan runs constantly. Any suggestions/comments?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Within the fan is a tachometer to monitor the fan’s RPM (feedback) that way the SMC logic can make sure to set the fan as the correct cooling level needed.
The error PPF003 really doesn’t tell us if the fan its self or the controlling logic is the problem. The easiest way is just replace the fan to see if that solves the problem or not. MacBook Air 13" (Late 2010-2017) Fan and here’s there guide to put it in MacBook Air 13" Mid 2013 Fan Replacement.
I would first get a soft paint brush and a can of can’ed air to clean the dust and debris thats collected inside out. Your fan may every come back to life! You may want to use a better way to monitor your systems thermals, I like this tool TG Pro
Imagem de MacBook Air 13" (Late 2010-2017) Fan
Produto
$29.99
Esta resposta foi útil?
Pontuação 0
1 comentário:
I cleaned the fan. I replaced the fan with a new one. Still the fan runs at full speed. I installed TPPro - no temperature issues. I ran ASD EFI software. “sensor - voltage (VPOR) — PBus reading below limit” No other sensor issues. Where is this sensor - anyone know?
por
Adicionar a sua resposta
Peter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 485
