Introdução
Use this guide to replace the fan.
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
20 outras pessoas concluíram este guia.
3 comentários
Do I need the artic silver thermal paste? I know the guide does not mention it, but a repair guy I went to first included it in the quote they gave me to fix the fan ($200 for parts and work for a fan replacement)
Arctic silver is a great thermal paste, but in my experience the swapping of the fans does not require any thermal paste. Thermal paste is usually used in between the connections of the computer's processor heat sink(s) and the processor, as well as the graphics card and the heat sinks.
