Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1697 Perguntas Visualizar todos
Got a ps4 that was in a roach infested house
Got a ps4 that was in a roach infested house, i opened it up to clean it out (only dead roaches found inside) but i pulled the power supply connector off the board. I don't have the tools to re connect and most places won't repair with signs of roaches. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Robert Boucher  you cleaned out all the roach debris? Follow as @tronicsfix suggest on here How much will it cost to clean a cockroach ps4
After that we would have to see how bad the damage is. Post some good pictures with your QUESTION so we can see what you see. Most traces can be rebuild and solder pads can be jumped etc. Again, we’ll have to see it.
Adicionar imagens a uma pergunta já existente
Something like this
should work for yours as well
Esta resposta foi útil?
Pontuação 1
Dump out loose remains in trash and vacuum as much as possible. Then clean and disinfect with 99% Alcohol and old soft toothbrush. try to stay away from tiny components on board unless there is roach dropping plastered all over it. No one will ever know there was a roach inside their unless you do a $@$*!& job.
Pontuação 0
Adicionar a sua resposta
Robert Boucher será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 213
