Ir para o conteúdo principal
RAM Upgrade Elitebook 8460P - PC3-10600s or PC3-12800s?
I have an Elitebook 8460p with Intel Core i5-2540m. It currently has 2x 4GB PC3-10600s. I wonder if I would face a problem if I upgrade it to 2x8GB Samsung PC3-12800s. According to the specs sheet,
Standard:
DDR3 PC3-10600 SDRAM (1333 MHz)
Two SODIMM slots supporting dual-channel memory
2GB, 4GB, and 8GB SODIMMs
Maximum:
Ungradable to 16GB with 8GB SODIMMs in slots 1 and 2
Dual-channel:
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
I am also planning to upgrade the CPU to Intel Core i7-2860qm which supports PC3-12800s in the future, so that's why I am considering PC3-12800s as an option. Please help.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi @cedric1689 ,
According to this major supplier the laptop supports DDR3 PC3-12800 (DDR3L-1600) SODIMM memory.
Near the top of the same page it states that the upgrades are guaranteed to be compatible
The “s” in PC3-12800s is used by some manufacturers to denote that it is 204 pin SODIMM (laptop) memory.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Cedric Boquiren, LPT será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 671
