Ir para o conteúdo principal
THINKPAD T520: Desempenho e portabilidade de alto nível.
Computer is on but screen black?
My laptop worked yesterday. Today I attempted to turn it on as usual, pressing the power button. It made all the usual noises. On startup, It makes a beeping noise, but that is normal. Today the screen is completely black. I can tell it’s on. The fans are running and the light is on. Still, the screen is black.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
DiamondWolf Gaming  connect an external monitor. If that works you know the issue is with your display. If it does not then it could be a GPU (motherboard) issue. Also while your computer is on, in a darkened room, shine a flashlight beam at an angle against the screen. See if you can make out your menu etc. If so you know it is a backlight issue.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
DiamondWolf Gaming será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 659
