Ir para o conteúdo principal
O Ninja Mega Kitchen System BL770 é um eletrodoméstico de cozinha completo fabricado pela SharkNinja.
Replacing broken plastic gears
Our Ninja BL700 stopped spinning. I disassebled the unit and the plastic 3 gear unit at the top had shredded teeth not allowing the unit to spin. Ninja does not offer a replacement part but saud I can purchase a replacement base. Does anyone know where I can purchase the part. An internet search has not been fruitful. Thank you.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
The person that answered your question isn't DIY savvy. You tore your unit down to find the 3 gear cluster inside the white casing. Apparently this is the main failure in the Ninja brand. I'm also trying to find a replacement, but you're the closest I've come to finding anything online.
por
Adicionar um comentário
1 resposta
If you are talking about the gear-looking part on the drive shaft that meets with the bottom of the blade assembly, it is called a coupler or coupling. I haven't found one for Ninja, but there are a lot for kitchen aid and waring around. I would wonder if one of these is 'compatible'.
Example: https://www.ereplacementparts.com/coupli...
Update (10/17/2020)
Similar question: The flexable rubber coupler has broken..
In that, this guide is referenced which includes a rebuild of the planetary gear assembly. I see now this is what you really needed
https://sites.google.com/site/dgeake51/h...
Esta resposta foi útil?
Pontuação 0
3 comentários:
No. It is the gear unit that turns the coupler.
por
Broken 3 gear unit that turns the coupler.
por
Adicionar a sua resposta
Tim Strickland será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 59
Ao todo: 2,484
