Ir para o conteúdo principal
O Corsair Void Pro RGB é um fone de ouvido sem fio ideal, compatível com a maioria dos dispositivos de mídia. Este conjunto possui alto-falantes duplos e um microfone.
speaker not working anymore
hello, i need help fixing my headset, the right ear stopped working, i opened it up and noticed that little chip that is glued to the speaker unglued, i tried re-gluing it but it still doesn't work.
i unglued the one on the left earphone to try to understand the issue, but once i put it back the left one doesn't work!
how exactly do headphones work? could it be that it wasn't just glue? (it sure looks like it! and it wasn't solder or anything conductive i think)
check pictures : https://imgur.com/a/LT20EqA
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I had the same question when I pulled mine off. Spoke to someone who works in fixing tech, he said it’s something called a soft solder and it wasn’t just glue. Take it to your local electronics shop and hopefully they can re-solder it somehow, that’s what I’m doing.
Esta resposta foi útil?
Pontuação 0
1 comentário:
how much would it cost to get it fixed? why not just fix it yourself? i'm sure there must be a tutorial, maybe not headset specific but still
por
Adicionar a sua resposta
brancamartino1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 587
