Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
Upgrade SSD from fusion drive
Hi
I want to upgrade SSD 4TB from my iMac fusion drive (1TB HDD and 128gb SSD).
Will this be ok?
My iMac is 27”, late 2014, 3.5ghz and 32gb memory.
Any suggest should I aware such as fan control will impact if I use this large of SSD?
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
A Fusion Drive is two physical drives a SATA drive Substituição do disco rígido do iMac Intel 27" com tela Retina 5K as well as a Blade SSD iMac Intel 27" Retina 5K Display Blade SSD Replacement.
So the first thing you’ll need to think about is which one are you replacing. While more work, the Blade SSD is by far the best swap out for performance!
OWC offers a Aura Pro X2 2.0TB NVMe SSD. If you are into video this is by far the best solution, making it your boot drive holding your apps and your active work.
Then upgrade your much slower SATA drive with a bigger HDD or SSD if you need deeper storage to hold your finished work.
Imagem de iMac Intel 27" Retina 5K Display Disco rígido
Guia
Nível de dificuldade:
Moderado
1 - 2 hours
Imagem de iMac Intel 27" Retina 5K Display Blade SSD
Guia
Difícil
2 hours
Esta resposta foi útil?
Pontuação 1
11 comentários:
Thank you for let me know.
To be clear of your suggest - I want to replace HDD to SDD which is no issue, but replace blade SSD is critical for the performance? if so, it is new to me as I thought just replace HDD to SDD…..
por
Also would this not affect the fan sound or heat control?
por
To get a better idea on the huge speed difference between the ports, give this a read! The Ultimate Guide to Apple’s Proprietary SSDs
A blade SSD won't alter your thermals negatively.
por
Hi I have upgraded SSD (first to cloned from HDD to SSD) and then it appear not working as block sign appear and I able to access disk utility but I don’t understand and don’t sure what happen. Can you help me please?
por
@razamac - You can't use cloning software any more! APFS volumes are very different from the older HFS+ volumes.
With the new drive mounted inside restart your system and press the Command (⌘)-R to enter into macOS Recovery: About macOS Recovery
Here's a bit more on the other startup keys: Mac startup key combinations
Then you'll need to connect your old drive to your system and use Migration Assistant to move your stuff over.
por
Exibir mais 6 comentários
Adicionar a sua resposta
Raza Hussain será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 3,359
