Replaced both the tub bearings and now the suspension rods- and it say
Replaced both the tub bearings and suspension rods- the tub bearings quietened the machine from roaring- and ran two perfect cycles before saying uneven load. I have also now replaced the suspension rods. Unfortunately it says uneven load still even with the machine empty? Help?
Esta é uma boa pergunta?
Pontuação
0
Kayla Sims exactly what model number is your washer?
por oldturkey03
@oldturkey03 wtw7600xw0
por Kayla Sims
Whirl pool cabrio. wtw7600xw0 @oldturkey03
por Kayla Sims
@Kayla Sims
Using one hand on each side, grab the inner tub, and see if you can lift it up. It should raise about an inch or so. If not the shaft may be sticking or gunked up or perhaps something may be caught under the tub.
por jayeff
