Hot water comes out warm.
When I select the hot cycle on my Kenmore Elite 796.29272900, it fills up warm. I have disconnected the hot hose at the wall and ran the water into a bucket and it is hot.
Thanks for your help.
Esta é uma boa pergunta?
@dwhome close off the cold water supply and see if it now fills with hot water. This sounds like a water inlet valve issue but could be thermostat/sensor issue. It may also be a cycle issue. Try to select something like Normal/Casual cycle and then select hot to see if that changes.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 55
