Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Using original 250 GB SSD as an external boot drive?
I hope I’m not the only one who still loves and uses a mid 2012 15’ Macbook Pro retina!
Some time ago I bought a Samsung EVO 860 1 TB SSD to replace my original internal SSD. I had to look around for adapters, but I got one that seems to work reliably (whenever I’ve tested it) and has good tolerances.
However, I’d like to find a way to still use the original 250 GB SSD externally, as a boot disk. I’m currently running 10.14.16 Mojave and would roll things back to an earlier OS on the smaller drive.
It’s hard to find a decent enclosure. Following other posters I came across the OWC Envoy Pro, but I can’t see for certain whether anyone used their SSD in this enclosure as a boot disk. Can anyone verify that this works?
Or do you have any other recommendations for a decent enclosure, that ships preferably from the EU?
Thanks for any and all responses!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I have a couple which work just fine!
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks @danj. Mine just arrived yesterday and I can confirm that so far, everything is working great.
por
Happy to hear it! Don't forget to acesspt the answer. Thanks!
por
Adicionar a sua resposta
M Kamengski será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 60
