Ir para o conteúdo principal
Aspirador robô da Samsung com conectividade Wi-Fi. Número do modelo: VR2AM7070WS/AA.
Vacuum Motor upgrade help
Hi. I have a very important question. Samsung powerbot vr7040 has 10w motor, can I replace this motor with 20w motor used in other models like vr7065 vr7070? Is there a problem with the electronic circuit? What kind of work should I do? I would be very happy if you could answer. Thanks.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hulusi Şen wondering why you would want to do that
por
Adicionar um comentário
1 resposta
The motor wouldn’t work, because the 20W motor would try and draw 20W from a 10W connection and circuitry, which would shut down the PowerBot or fry the circuits. I’d heavily recommend looking for the proper part.
Not sure where’d you’d find the part, but good luck!
Substituição do motor de aspiração do Samsung POWERbot R7070
Esta resposta foi útil?
Pontuação 0
1 comentário:
I understood. I got the answer I was looking for. thank you very much.
por
Adicionar a sua resposta
Hulusi Şen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 20
Ao todo: 383
