Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
559 Perguntas Visualizar todos
Post-battery replacement, battery unglued / unstuck
I performed a battery replacement with the iFixit repair kit. The battery works well, but the adhesive of one of the cells didn’t hold, and the battery is now rattling around inside my case.
Oops…
What should I do to fix it?
Esta pergunta é pertinente?
Pontuação 5
1 dos comentários
Same here. IFixIt sent me some kind of duct tape which i used but quickly to no avail.
por
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
@mishchea some doublesided tape like this Tesa 61395 Tape or others that fit, strategically placed should be sufficient to hold it in place. Lots of room would lead me to some velcro which will make the next battery replacement easier :-)
Imagem de Tesa 61395 Tape
Produto
Tesa 61395 Tape
$5.99
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks for the suggestion -- what width would you recommend for the tape? 8mm? 4mm?
por
@mishchea you got lots of room. Go for the 8mm
por
Adicionar a sua resposta
Andrey Mishchenko será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 185
