Ir para o conteúdo principal
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
20 Perguntas Visualizar todos
Apple Watch water damaged due to screen crack
My Apple Watch series 4 screen cracked unfortunately while washing my hands water fallen on force fully
on that time I just wiped & after 1 hour I put on charge but it won’t Turing on
then I shake my watch some water drops came out
I just put nearer to fan to dry completely
does it survive or completely dead
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Pergunta mais útil
Ouch! Sadly once water gets inside its very difficult to fix. I think its time to get a new watch.
Esta resposta foi útil?
Pontuação 1
8 comentários:
This fine morning it just booted up when I was put on charge
But now problem Is not charging it was stuck 1%
por
Yep! Its a sad puppy ;-{
por
Then what is the next step have to do ?
por
Do you have a recycler which you can drop it off so the battery and the other materials are properly recovered. Some even offer money! Sadly, not much.
por
I ask for repair guide
por
Exibir mais 3 comentários
If you have the tools and think you know how to take it apart, try taking it apart by following iFixit’s guide found here: Apple Watch Series 4 Battery Replacement
Apple Watch Series 4 Screen Replacement
(These guides are the furthest iFixit will tear down the watch, the tear down does disassemble it further, but it doesn’t show precise instructions)
After this, try cleaning off any corrosion you see with a clean toothbrush and isopropyl alcohol. If you don’t see any corrosion, lucky you. Mine had lots of corrosion everywhere.
While you’re in there you can also replace the battery if you want and make sure to replace the screen adhesive, also you might want to fix the screen as well. Keep in mind that the watch likely won’t ever be waterproof again, even with a new screen and adhesive, so be careful not to expose it to water.
If I were you I would take it apart to try to clean it, since you have nothing to lose if the screen is cracked and it won’t turn on. You will need a hobby knife (about $10) and a tripoint Y000 screwdriver (Tri-point Y000 Screwdriver
Buy a high quality tripoint screw driver, the cheap ones strip very easily.
Also, don’t worry about destroying the Force Touch sensor. In WatchOS 7 it’s completely disabled anyway.
Edit: changed screwdriver to correct size
Imagem de Precision tri-point Y000 screwdriver engineered by iFixit and manufactured in Germany. Sometimes referred to as "y type" or "y shape", compatible with Apple Watch and late model iPhone screws
Produto
$5.99
Imagem de Apple Watch Series 4 Battery
Guia
Nível de dificuldade:
Difícil
1 - 2 hours
Imagem de Apple Watch Series 4 Screen
Guia
Difícil
1 - 2 hours
Pontuação 0
I would still try to put it in a bag of uncooked rice for a couple of days.
Pontuação -1
1 comentário:
Sorry guy this is an old urban legend!
Rice or any other decadent won't dry out your device! It's no better than placing a dry sponge on your device. Unless the wetness inside turns into a vapor it can't absorb it.
Give this a read! Don't Put Your Device in Rice. Here's Why
por
Adicionar a sua resposta
Feroz Mohammed será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 4,646
