Ir para o conteúdo principal
Apple Watch Series 4 Battery Replacement
O que você precisa
  1. Apple Watch Series 4 Battery Replacement, Display Opening: passo 1, imagem 1 %32 Apple Watch Series 4 Battery Replacement, Display Opening: passo 1, imagem 2 %32
  2. Apple Watch Series 4 Battery Replacement, Safety Requirements: passo 2, imagem 1 %32 Apple Watch Series 4 Battery Replacement, Safety Requirements: passo 2, imagem 2 %32 Apple Watch Series 4 Battery Replacement, Safety Requirements: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Safety Glasses
    $3.19
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch Series 4 Battery Replacement: passo 3, imagem 1 %32
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
  4. Apple Watch Series 4 Battery Replacement: passo 4, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 4, imagem 2 %32 Apple Watch Series 4 Battery Replacement: passo 4, imagem 3 %32
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the Force Touch sensor.
  5. Apple Watch Series 4 Battery Replacement: passo 5, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 5, imagem 2 %32
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Apple Watch Series 4 Battery Replacement: passo 6, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 6, imagem 2 %32 Apple Watch Series 4 Battery Replacement: passo 6, imagem 3 %32
    • It's likely that the Force Touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
  7. Apple Watch Series 4 Battery Replacement: passo 7, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 7, imagem 2 %32 Apple Watch Series 4 Battery Replacement: passo 7, imagem 3 %32
    • To avoid straining the display cables, don't open the display all the way yet.
    • Open the display at max. to an 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
    • Thread the adhesive around and behind the display cables to get it off completely. Since the adhesive needs to be replaced anyway, you can cut it if that makes removal easier for you.
    • Make sure to return to this point during the reassembly of your watch and then continue with the Resealing Procedure.
  8. Apple Watch Series 4 Battery Replacement, Battery: passo 8, imagem 1 %32 Apple Watch Series 4 Battery Replacement, Battery: passo 8, imagem 2 %32
    • Carefully fold the screen to the back until you get enough space to pry out the battery.
    • Avoid tensioning the display cables when folding the screen to the back.
    • Insert an opening pick between the battery and the Taptic Engine.
    • A regular opening pick works fine with the 44mm version of the Apple Watch Series 4. However if you own the 40mm version and don't have enough space you can customize your opening pick with scissors.
  9. Apple Watch Series 4 Battery Replacement: passo 9, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 9, imagem 2 %32 Apple Watch Series 4 Battery Replacement: passo 9, imagem 3 %32
    • Slide the opening pick along the edge of the battery to loosen the adhesive.
    • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
    • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  10. Apple Watch Series 4 Battery Replacement: passo 10, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 10, imagem 2 %32
    • Carefully lift the battery and bring it in a 75° angle.
    • Use a pair of tweezers to peel the black sticker off the metal plate which covers the battery connector.
  11. Apple Watch Series 4 Battery Replacement: passo 11, imagem 1 %32
    • Remove the Y000 screw (1.2 mm length).
  12. Apple Watch Series 4 Battery Replacement: passo 12, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 12, imagem 2 %32
    • Use a pair of tweezers to remove the metal plate which covers the battery connector.
  13. Apple Watch Series 4 Battery Replacement: passo 13, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 13, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the battery flex cable.
  14. Apple Watch Series 4 Battery Replacement: passo 14, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 14, imagem 2 %32
    Tesa 61395 Tape
    $5.99
    • Remove the battery.
    • Be sure to remove the protective liner to expose the adhesive on your new battery before you set it in place.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
  15. Apple Watch Series 4 Battery Replacement, Display Adhesive: passo 15, imagem 1 %32 Apple Watch Series 4 Battery Replacement, Display Adhesive: passo 15, imagem 2 %32
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • The following steps describe how to apply replacement adhesive in preparation for the resealing procedure.
    • Apply a little bit of high isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on top of the Force Touch gasket.
    • To remove the adhesive on the edge where the display cables are running, fold down the display and carefully pull it away from the frame so there's enough space for cleaning.
  16. Apple Watch Series 4 Battery Replacement: passo 16, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 16, imagem 2 %32
    • Flip the Apple Watch upside down so the display lays flat while lifting up the case.
    • Remove the leftover adhesive from the back of the display.
  17. Apple Watch Series 4 Battery Replacement: passo 17, imagem 1 %32
    • Use a pair of tweezers to carefully remove the replacement adhesive with the blue protective film from the backing paper.
  18. Apple Watch Series 4 Battery Replacement: passo 18, imagem 1 %32 Apple Watch Series 4 Battery Replacement: passo 18, imagem 2 %32
    • Hold the replacement adhesive diagonally to thread it over the display.
    • Slightly tilt the display forward so you can align the adhesive with the frame.
    • Position the replacement adhesive on top of the Force Touch gasket.
  19. Apple Watch Series 4 Battery Replacement: passo 19, imagem 1 %32
    • Use the pointed end of a spudger to make final position adjustments and press the adhesive into place.
    • Follow the resealing guide to reseal your watch after reassembly.
Conclusão
To reassemble your Apple Watch Series 4 follow these instructions in reverse order to reattach the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
42 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
229.354 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.450 guias
5 comentários
Is the adhesive waterproof?
laws - Responder
Hi laws,
iFixit makes no claims to the continued splash-resistance of the Apple Watch after applying this adhesive strip. It's probably going to be just fine, but we can't confirm that the Apple Watch will maintain its IPX7 waterproof rating after being repaired.
Dominik Schnabelrauch -
Ich habe jetzt 2 Uhren durch - besten Dank für die Hilfestellung. Ich habe mir die “Dichtungs-Klebestreifen” besorgt, waren für mich aber nicht praktikabel. Bei beiden Uhren hat sich die Force-Touch-Dichtung teilweise gelöst und der Klebestreifen hat zwar auf der FT-Dichtung gehalten, aber das Display kam wieder hoch, da der die FT-Dichtung eben nicht mehr am Gehäuse geklebt hat.
Ich habe mir eine Tube Smartphone-Dichtmasse besorgt, damit konnte ich die FT-Dichtung wieder befestigen und habe damit auch das Glas wieder optimal einkleben können. Da sich sich die Masse (wie die Klebestreifen auch) bei Hitze wieder entfernen lässt: für mich die praktikablere Lösung. Auch nicht ganz so frickelig…
carver - Responder
Wie heißt der Kleber? T-7000?
joachimschreiter -
Why is the replacement battery slightly larger than the original? 10 hours of pressure applied after reattaching the display and heating it, but as soon as it's put on a charger, the replacement battery swells up a bit and pushes the display up
Will Drunkenstein - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 106
Últimos 7 dias: 710
Últimos 30 dias: 2,695
Duração total: 145,958
