Hi Matthew, so I am no expert, but judging from the pictures you sent it does not seem like the receiver was damaged and could still be funtional. My suggestion would be to gently wigle the reciver left and right while pulling it out of the laptop. Then look and see what the correct orintion is for the black casing of the reciver would be. After that apply a small amount of super glue to the inside of the casing (not so small that it does not stick, but also not so much that super glue will ooze out of the casing). Lastly, put the casing back on the reciver in its correct orintion. I hope your mouse works and best of luck to you!
I say use superglue since for me it is easier to control how much glue I want to use, and I find that it works well in terms of strength for plastic.
HI
Do you have the model no of the mouse?
Adding images to an existing question.
por Augustine
Hello Matthew, for some reason I can't see the pictures you attached, but if you can give a bit more information I can try to help!
por Mohammadali Khalifa
@maker600 oops! I'll try adding them
por Matthew Chambers
@salmonjapan I'm not sure, do you mean the number of my specific mouse and keyboard or the model itself?
Haha it happens, but i will take a look once you do. Hopefully i can try to help. :)
Mostrar mais 2 comentários
