Ir para o conteúdo principal
A sexta iteração do smartphone carro-chefe da OnePlus e sucessor do OnePlus 5T. Lançado em maio de 2018.
Oneplus 6 screen falling off, please help.
Yesterday, while i was using my phone normally, I noticed that the screen of my oneplus 6 is coming off slightly, from the bottom. Everything is fine. I didn't drop the phone, and there are no scratches on the screen either. The screen works completely fine, and there are no touch response issues. I think its because of loosening of the adhesive overtime, holding the screen to the frame. Is there any solid solution, without removing the back of the device, and withlut completely replacing the screen (because the screen is completely fine)? Please help. Thanks in advance.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
For a permanent fix, you’ll have to open the device, seperate the display, and re-adhere it into place.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi
Where do you buy the glue to stick the screen?
por
@sharonchai sorry for the late reply, but just search for Tesa 2mm double-sided tape or B/T-7000 adhesive on your favourite online marketplace.
por
Adicionar a sua resposta
Prasanna Laxmi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 2,575
