Ir para o conteúdo principal
O maior dos notebooks MacBook Air da Apple, com microfone duplo e conectividade Wi-Fi 802.11ac.
NEN AV7 capacitor replacement
One capacitor on my MacBook Air 2013 is defective and I need to replace it. It’s code is NEN AV7.
I found a new capacitor but with code NEE AV7. Can I use it to replace the defective one?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
How about posting a few pics, one the area and one zoomed in on the cap in question so we can try to identify it from a boardview drawing.
Also, is the system working currently or not, as well as if you are having any difficulties.
por
@danj
The component on the logic board 820-3437 is indicate as C7143.
It’s part of PPVBAT_G3H_CHGR_REG.
The capacitor C7143 (coded on the surface as NEN AV7) has the following characteristics: 62uF, 0.023 OHM, 20%, 11V, tant-poli, case B2S-1.
My question is if the NEE AV7 which I found has the same characteristics. I believe so, but I’m not sure
por
Adicionar um comentário
1 resposta
Solução escolhida
You have the correct values so you should be fine.
Imagem
Here’s a link to the product guide NEC Token Tantalum Caps
Here’s the breakdown of the codes for these caps
Imagem
So…
NE = NeoCapacitor and the Letter C = 2013 date code
AV7 - is the value of the capacitor
Esta resposta foi útil?
Pontuação 2
1 comentário:
Clear.
Appreciated your fast reply! Thanks a lot!
por
Adicionar a sua resposta
Albi B será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 52
Ao todo: 9,795
