Replace the paste on the GPU on the iMac Intel 17"
Which one of the two heat sinks has the GPU underneath it?
Should I reapply the thermal compound on both heat sinks while I'm at it?
Esta é uma boa pergunta?
I would use the CPU fan replacement guide to point to which one is for the CPU. That guide is here. Personally if you are having heat issues I would reapply thermal compound/paste to both the GPU & CPU. You do not apply thermal compound/paste to the heat sink, it is applied to the processor - thin as possible, yet still covering. A rough guide for applying thermal compound is here. I recommend using the Arctic silver thermal compound/paste available here.
Guia
Nível de dificuldade:
Moderada
5 - 20 minutes
Guia
Difícil
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,860
