Ir para o conteúdo principal
Refrigerators produced by Samsung.
256 Perguntas Visualizar todos
What is this brown liquid leaking from my Samsung refrigerator?
I have a Samsung dorm-room-size refrigerator and, while picking it up and moving it, a brown liquid that looks like Vanilla Extract or thin Chocolate Syrup started leaking from the bottom. What is it? Should I replenish it? Will running the refrigerator damage it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
@stephenspeer kind of hard to make out but it looks like it maybe coming from your compressor. It’s actually the only thing that would have that type of fluid in there. IF it is, that would mean your compressor is leaking and needs replacing. Hard to come by and you may need a professional to do it. Of course this is only from looking at the picture. Make sure that it is not something out of your fridge that may have spilled etc.:-)
Esta resposta foi útil?
Pontuação 0
6 comentários:
It has no smell, so it’s not likely spoiled food. The fridge has been empty for weeks.
por
then the most likely source is a bad compressor.....
por
1. Will it hurt anything to run it?
2. Is the fluid replaceable or does it require a new compressor?
por
It'll get your compressor to overheat and fail. You'll need a new compressor (
por
Which I need anyway because I can’t replenish the fluid Right?
por
Exibir mais 1 comentário
Check your compressor bro, it might need gas fill up or change
Pontuação 0
Adicionar a sua resposta
Stephen Speer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 3,413
