Old 2008 to 2010 Sanyo Tv turns off on it own
My tv still works and turns on but every now and then it just turns off all by itself. We turn it back and the screen still works just turns off on its own. It can stay on for long while or for short intervals but the picture has never gone out. I’ve checked the cord in the wall and the connections on the back of the tv everything looks good. I’m not sure what it needs so it doesn’t keep doing that. Any help would be great. Thanks
Esta é uma boa pergunta?
7 comentários
Hi,
What is the model number of the TV?
Check that any air vents in the TV back cover are clear and free of dust etc, so as to allow the hot air to escape to prevent overheating. Use a vacuum cleaner to clean them if necessary
por jayeff
I’m not sure. How do I check the model number? Actually I just figured it out the model number is DP32670.
por Juanita
No, the power in dictator doesn’t turn off. I never really noticed it but it doesn’t and the screen goes black with no audio. But I did notice that when I touch or put slight pressure on the right side the screen goes black. It might have to do with a line I’ve seeing on the screen for some time now.
por Juanita
@jaxlb where on the screen did you see this "It might have to do with a line I’ve seeing on the screen "? This "I touch or put slight pressure on the right side the screen goes black" of course before it goes black and no audio? Bottom right side or top?
por oldturkey03
I’ve attached a picture to my question.
por Juanita
Exibir mais 2 comentários
